500 caddy motor into iroc
Old Oct 7, 2008 | 07:50 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
My buddy picked up a 500 big block caddy motor and we were thinking of throwing it into a thirdgen. What would we need to make it happen? I've seen 472s in chevelles before so i know its been done. Would we be better off with a second gen?
Old Oct 7, 2008 | 08:15 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Re: 500 caddy motor into iroc
I have to ask: have you done a search yet?
ok, I've seen a couple pics of caddy's in the 3rd gens. One even had an external link to his sight where he cut away at the firewall to move the engine back some to for better weight distro.
Old Oct 7, 2008 | 08:18 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
yeah i searched i didnt find anything
Old Oct 7, 2008 | 11:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Look again.
I haven't seen anyone post about a clean swap. The last one I recall was pretty sorry (cut a hole in the front of the hood for clearance).
Old Oct 8, 2008 | 12:48 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Hey! I LIKED THAT ONE! hahaha
Anyway, he did have some good pictures of the engine mount setup and that is the hard part anyway. I think it was called cadmaro, but I don't remember.
Keep searching, dang near everything has been done here before at least once!
Old Oct 8, 2008 | 07:43 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
what did yous search for i tried 500 caddy motor 500 caddy swap didn't find nothin
Old Oct 8, 2008 | 09:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Don't use "500" in your search. The only difference between the 472 and the 500 is the stroke. Externally, the engines are identical.
Old Oct 9, 2008 | 08:33 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I have those pictures saved "somewhere", I just don't remember where I saved them though. His website had about 4 pages of pictures before he seized the buildup. It was a Blue '86 Trans Am w/T-Tops and LG4, and the owner gutted the entire car. He cut the firewall to move the engine back some, and he welded in a nice piece that he fabricated himself in it's place. I'll try to look for them when I get home from work....
Old Oct 9, 2008 | 07:20 PM
Engine: 5.7 / 7.4
do a search on: cadillac
Old Oct 10, 2008 | 02:59 AM
seb.a's Avatar
Car: 1983 Trans Am MSE
Engine: LG4
Transmission: TH700R4
Axle/Gears: 10 bolts 3.73
watch for project dislexia
Old Nov 30, 2008 | 11:44 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
Good luck if you try this. I thought about it a while back but decided it would be too much of a hastle. These engines fit easily into G-Body's, but it might be tight in an F-Body. If you can get a 454 to fit in a 3rd gen, it's probably possible to get a 500 in since they aren't much wider...and they are actually lighter. Not sure about hacking up the firewall and all that...weight distribution shouldn't be much different than a big block swap. Again, not familiar with big block swaps, but you might want to check out the cadillac forums. They have forums dedicated to that engine so you might want to check them out if you are serious.
Old Nov 30, 2008 | 01:44 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The Caddy engine is a torque motor, not a HP motor. In stock trim, it's only good to about 4500 rpm. The valve train doesn't like high rpms.
Swapping in a BBC is easier and cheaper.
Old Nov 30, 2008 | 02:37 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Aftermarket k-member, modified pan, custom headers and exhaust, larger radiator, and some practice with torches and a mig..... There used to be one of these in Fort benning a couple years back. He ran without a hood, but had the sides smoothed off so it looked like it was meant to be that way. I wish I could remember everything he did to it.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Irocohio
Aug 12, 2015 08:03 AM
mustangman65_79
Aug 11, 2015 03:17 PM
NBrehm
Aug 5, 2015 07:57 PM
