GM 290 horse 350 under TPI
Car: 1990
Axle/Gears: stock
Re: 350 Swap problems
You can pick up a 290 hp 350 that is pre 86 pretty cheap. But everyone tells me that I cant run my tpi on it. I already know to change the heads with those of 72 degrees for the center bolts, but what else will prevent it from running? Everyone I talk with wants to sell me $3,000.00 worth of engine when I dont think I need it. I'm not going to race it, just want to pull nicely up to 5000 rpm when I need to. I also know about the flex plate and balancer.
Transmission: 4L80E/4L80E
Moved your post to a new thread, as this doesn't have anything to do with the thread you posted in.
Sanjay
Aug 12, 2015 03:41 PM
