Early and late 350 engines.
Old Nov 19, 2008 | 02:04 AM
thebandit92's Avatar
Car: 91 Trans Am 5.0
Other than heads and intake are earlier engines the same as later ones,i am only interested in knowing if the blocks are same around engine mounts to see if a ,89 350 tpi from a Trans Am engine will bolt into '85 and earlier cars or are engine mounts different,if they are will the earlier mounts bolt straight on to later engines.
Thanks Jimmy.
Old Nov 19, 2008 | 11:09 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Early and late 350 engines.
That's easy. Have at it.
Old Nov 19, 2008 | 11:42 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Any small or big block Chevy from 1958 on will have the same mounts and bellhousing.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
angel2794
Sep 8, 2015 06:22 PM
TheTraut88
Sep 7, 2015 05:22 PM
greenyone
Aug 29, 2015 11:08 AM
Eric-86sc
Aug 24, 2015 09:01 PM
