LT1+L98?
Car: 1986 IROC
Engine: 5.0 TPI
Transmission: AUTO
Axle/Gears: 3:73 posi
LT1+L98?
I have a pair of heads out of an LT1 vette. I have an 86 z28 with a 350 tpi. curious if the heads will match to the block. I know the intake will need to be swapped, not sure about heads.
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
Re: LT1+L98?
uhh..they can b modded for the swap....but lt1 heads are reverse cooled engines...its takes coollent form the back of the head......bolt it unmodded to a gen 1 block coolent will go rite in the valley pan(or something)
Transmission: 4L80E/4L80E
Sell them, buy a set of Vortec heads. Cheaper, as good as performance on an L98.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
