small block 400
Old Dec 5, 2008 | 10:46 AM
86 iroq's Avatar
small block 400
i just installed a small block 400 in my 86 iroc! and when i get on the freeway or over 50 mph it runs at 220 to 240 and i was wondering if its my computer because it thinks its still a 305! if anyone has seen this problem or has a clue to help me out please fill me in because im not shure what it is! thanks!
Old Dec 5, 2008 | 10:49 AM
noroxus's Avatar
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
Axle/Gears: 9 bolt 3.27 Posi
Re: small block 400
computer has nothing to do with that. its time for a new radiator. 400s like to build heat.
Old Dec 5, 2008 | 12:01 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: small block 400
400s running extra hot is an urban legend. The only time it's true is if the heads and/or head gaskets don't have the steam holes.
First thing to check is the secondary air dam directly under the radiator.
yes, 305 programming is too lean for a 400, and lean=hot, but you would have surging and other noticeable symptoms. The idle circuit for the 305s proved adequate to Chevy's own SkunkWorks when they were developing the emissions-legal ZZ3 conversion, so that system can obviously feed a bit more than just a 305.
Old Dec 5, 2008 | 12:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The programming isn't too lean, it's just looking for an O2 voltage output that corresponds to stoich. It could be the carb (this is a carb, not TPI, right?) idle mixture or main jets aren't big enough, but I doubt that under cruise conditions. Did you adjust the IAB after putting the carb (this is a carb, not TPI, right?) on the 400?
Old Dec 8, 2008 | 08:29 AM
86 iroq's Avatar
Re: small block 400
i have the stock tuned port injection on the motor with high output excell injectors
Old Dec 8, 2008 | 11:09 AM
86 iroq's Avatar
Re: small block 400
where can i get the emissions-legal ZZ3 conversion?
Old Dec 8, 2008 | 12:11 PM
five7kid's Avatar
You can't. That was for carb to start with, and has been discontinued.
Okay, you've got TPI. Still, shouldn't be a problem cruising down the highway.
Is your SES light coming on? Do you have means to scan data like an Auto X-ray?
Old Dec 9, 2008 | 08:18 AM
86 iroq's Avatar
Re: small block 400
there arent any lights on and i have a code scanner not an auto x ray! but when this thing idles it runs at 190 deg. someone told me that i have to drill holes in the block and in the heads for cooling, is that true?
Old Dec 9, 2008 | 09:57 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: small block 400
didn't realize you weren't carbureted, sorry. Anyway, the block already has the steam holes, as SHOULD the 400-specific head gaskets you shoulda used. If your heads are not factory GM 400 heads, they hafta have the steam holes added. You can use the gaskets as a template, but the holes must be drilled at an angle. Any decent automotive machine shop should be able to give you the details for free.
Old Dec 9, 2008 | 02:28 PM
five7kid's Avatar
From World Products' instructions:
"If steam holes are desired, it is necessary to drill six 1/8 steam holes. To drill, invert the cylinder head with the deck side up. Using a head gasket
as a template, center punch the head where the steam holes will be drilled. The three steam holes closest to the intake side of the head must be drilled
at a 30 degree angle toward the exhaust side of the head. The remaining three steam holes that are closest to the exhaust side will be drilled straight
down.
Old Dec 9, 2008 | 08:53 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: small block 400
He's almost right... no drilling on the block, just the cylinder heads. Because theres no coolant passage between the cylinders in the block, GM put a new set of coolant passage holes in the heads. But Only on the 400. If you have heads that weren't originally for a 400, you'll have to take them off and drill those holes.
Use a 400 head gasket as a template, and follow the instructions Five7 posted. Should be problem solved after that
Old Dec 10, 2008 | 09:30 AM
86 iroq's Avatar
Re: small block 400
i was trying to avoid that, but i gotta do what i gotta do to get it running good! thanks everyone!
Old Dec 10, 2008 | 10:33 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: small block 400
Why try to avoid it?
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
