LT1 & 700R4
Old Dec 8, 2008 | 06:26 PM
93BlackTa's Avatar
Car: 93 Trans Am, 89 Iroc Convertible
Engine: 383 LT1, 350 LT1 going in the Iroc
Transmission: T56, 700r4
Axle/Gears: Moser 9" w/3.89, 10 bolt w/3.42
LT1 & 700R4
I am going to be swapping an 93 LT1 engine into my 87 iroc. Will i be able to keep the 700R4 for the engine swap? It should bolt upto the LT1 right? Will i use the 305TPI flexplate/flywheel that is in the car now? How about the speedometer? if i was going with the 4l60 or t56 then i would need a box to convert the signal right, If i use the stock speedo and the 700R4 tranny then i shouldn't have to make any changes should i for the speedo to work?
Old Dec 9, 2008 | 12:03 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: LT1 & 700R4
A '93 700R4/4L60 for a '93 LT1 is the exact same trans as the 87-92 700R4/4L60 that came in thirdgens. However, '87 was the changeover year, so there's no telling if yours is the newer style or the older style. Externally they're the same so it will bolt up to the LT1 just fine. Its the internals that are different and stronger in the newer versions.
The speedometer gears are the same too. Those were not changed until the '94 4L60-E models.
The 93+ T56 will need a converter box.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
