383 HSR w/30lb injectors flooding itself out
Old Dec 8, 2008 | 10:35 PM
peepsrs's Avatar
Car: 91 Rs
Engine: 383 hydrolic roller carb
I have a 91 camaro with an 86 tpi computer and harness. My motor is a 383 hsr w/ 30lb injectors and a stock maf. the motor when I first fired it up it ran well for a week or so and I believe the IAC valve went bad and the car started runnin like crap and flooding itself out. I then replaced the iac and it ran well for a lil bit but then resorted back to flooding out and not wanting to run? I am not getting any engine codes from the computer and all sensors are new and I was wondering if anyone had any Ideas? I am tempted try the injectors b/c I think they might be getting stuck open but I am unsure still on what my next step would be...just trying to get some ideas if anyone has any.
brandon
Old Dec 9, 2008 | 09:40 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Re: 383 HSR w/30lb injectors flooding itself out
brandon
Is it a stock chip or has it been reprogramed to work with the 30lb injectors?
Old Dec 9, 2008 | 10:13 PM
peepsrs's Avatar
Car: 91 Rs
I had pcm for less burn me a chip for the specs of the motor I think I might have figured it out but Ideas are always helpful.....
Old Dec 11, 2008 | 09:05 PM
acadburn's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
id assume the people that made the chip didnt know or forgot about the 30lb injectors which could be flooding it out or.... a major timing issue..... maybe.. only ideas i have
86CamaroDan
Sep 29, 2015 10:08 PM
BAMiller
Sep 14, 2015 06:38 PM
Nick McCardle
Sep 10, 2015 08:36 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
355tpipickup
Sep 4, 2015 05:32 PM
