350 Engine question
Old Jan 10, 2009 | 01:13 AM
ThermalTrans's Avatar
Car: 85TransAm,97Firebird(Formula)
Engine: 305 5.0L,5.7LTI
Transmission: 700R4,Tremec 56
350 Engine question
I have a 70's 350 with all stock parts and was wondering with a new cam how large in terms of Lobe and Lift and Duration I could go without a loss in horsepower. If that makes any sense. Thanks guys.
Old Jan 10, 2009 | 01:17 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 350 Engine question
What heads do you have? The real question is how much lift can you get without breaking things.
Old Jan 10, 2009 | 01:21 AM
I'm not sure atm. Its not really for me and I was asked to help out a friend and this was the most knowledgeable place I knew to come to. He said he wanted to be able to put the largest cam in without losing HP so he would net gain, or thats what he told me. All the components are from the 350 to the best of my knowledge its from a Chevy 3/4 Ton Rear wheel drive. He's redone all the rings and port polished all the cylinders and everything so its basically renewed on the inside.
Old Jan 10, 2009 | 01:23 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You really need to know what heads it has to choose a cam. "70s 350" could mean just about anything, and usually nothing good. It doesn't take much of a cam before the heads can't keep up.
Old Jan 10, 2009 | 01:30 AM
Ok thanks. I'll get that information and come back at some point. Thank you.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
