502 steering pump pulley problem
Old Feb 5, 2009 | 03:24 AM
engongam's Avatar
Car: 1991 Trans Am GTA
Engine: 502 Ram Jet
Transmission: TKO600-racing gears
Axle/Gears: 12 Bolt Moser-33"axles-3.91 ratio
hello again,
I am about to crank the motor up but I havesome problems,
I am using the original accesory drive kit for big blocks, but the steering pump pulley hits the steering box, If I use a smaller pulley with some modifications on it(march ), It will work fine.
The real question is, will it effect the performance of the steering pump?
other question is that my old dual fans don't fit, do you have any suggestions?
I might go with a thinner one, but be cool's dual fan set doesn't fit either...
I will add some photos tomorrow
The orginal thread is here: https://www.thirdgen.org/forums/engi...ml#post4002661
Old Feb 5, 2009 | 01:52 PM
engongam's Avatar
Engine: 502 Ram Jet
Re: 502 steering pump pulley problem
Here is how it looks.... Is it ok to usa a much smaller pulley? Will it cause any differences...??
evilstuie
Jan 9, 2020 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
mcquigg
Aug 13, 2015 02:26 PM
Street Lethal
Aug 12, 2015 11:33 AM
