Iroc 305 engine change, need some info
Old Feb 6, 2009 | 12:59 PM
IROCmatt's Avatar
Car: IROC Z28
Engine: 5 litre 305
hi ive got a 86 iroc i bought it with a seized engine, its a 305 ive bought another 305 engine but its a 88 i did not realise they were slightly different, the cars tpi, can i grind the injection maniold bolt holes to make fit the newer engine, also is there anything else i should know thats going to be different? as im learning about it as i go along, i was told the engine ive bought was running tpi but if it had a carb would it still run tpi?
any info much appreciated
Old Feb 6, 2009 | 01:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
You pretty much summed it up. '86 was the last year (other than aluminum headed Corvettes) that had all the intake manifold bolts at the same angle. You could get an '87-later TPI base, and it would then all bolt up. Otherwise, like you said, elongate the center two manifold bolt holes on each side until the bolts fit.
No problem putting the TPI back on the '88 engine. As long as the cam hasn't been changed.
Old Feb 6, 2009 | 02:15 PM
IROCmatt's Avatar
Car: IROC Z28
Engine: 5 litre 305
Re: Iroc 305 engine change, need some info
ideal thanks for that, not sure about the cam im in the uk so parts are hard to find, pretty much impossible to find a tpi manifold for the new engine so ill have a go at grinding the old holes, is there anything else different?
i was told the new engine ran tpi but its just the guys word for it.
Old Feb 6, 2009 | 04:02 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Go to a yunk yard and find what you need, or you can cough up a little bit more and buy a new manifold.
Bone yards ftw!~
Oh I didnt see that your in the UK. Got any pic's of the manifold ?
Old Feb 6, 2009 | 04:17 PM
IROCmatt's Avatar
Car: IROC Z28
Engine: 5 litre 305
not got a pic of it, it looks like i can get away with using it, just wondering i there's any thingelse different
Old Feb 6, 2009 | 05:00 PM
five7kid's Avatar
The valve covers are different, but that won't affect this operation. The '88 also has roller lifters, but again, won't affect anything you're doing.
84z96L31vortec
Aug 20, 2017 12:16 AM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 11, 2015 03:17 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
