Engine Question!!!!!!
Old Feb 18, 2009 | 10:02 PM
Dime333's Avatar
Car: 1985 Camaro Z28
Engine: 305 5.0L (LB9)
Transmission: 700R-4
Axle/Gears: No idea
Is it a downgrade if i put this 327 in my camaro? does the age affect it any?
http://denver.craigslist.org/pts/999216290.html
i currently have an LB9
Old Feb 18, 2009 | 10:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Engine Question!!!!!!
By todays standards with engines, yes. The 327 is a better bore/stroke combination than a 305 but it's not as good as a good 350.
That old engine will be hard to use. The heads probably need to be completely redone. The heads won't have accessory bolt holes etc. Personally, it's not worth the asking price unless you need the old engine for a numbers matching rebuild or you need the old casting numbers for a racing class.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
