305 to 383 stroker
Old Feb 20, 2009 | 09:05 PM
dynamic123's Avatar
305 to 383 stroker
hey bros, i have a 84 camaro z28, with a 305 engine, want to put a 383 stroker crate engine, GM mechanic says to much power and the car can twist. it is a t roof car. recommends i install a 350 in this car. any suggestions on the 383/427 hp. ii is a patriot engine. please help. thanks.
Old Feb 20, 2009 | 09:09 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: 305 to 383 stroker
Weld in sub frame connectors... wonder bar, strut tower brace, Rear Lower control Arms / Panhard bard (adjustable if you changed the springs or stock tire size... Good tranny and rear end... have fun!
Raf
Old Feb 20, 2009 | 10:33 PM
moedogger's Avatar
Car: still lookin
Raf
x2
Old Feb 25, 2009 | 09:56 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I have a 1984 Pontiac Trans Am T-top car with a Minirammed 385 stroker, with 400+ RWHP on the dyno rollers. That's about 460 - 475 HP at the crank. It's a low 12-second, 114 MPH car.
Even before swapping motors I was getting wrinkling in the sail panels, because I drag raced and autocrossed it a lot. Once I installed subframe connectors, all those problems went away. you need subframe connectors, lower control arms in the rear, and an aftermarket panhard rod. Those three parts first. Then, go through your axle and put in an AAM axle cover with integrated stud pre-loaders. It'll help hold the axle together. After that, you should be okay with 383 power.
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Gambit TA
Sep 1, 2015 07:27 PM
TEEZER TA
Aug 30, 2015 06:35 PM
