tbi heads?
Car: 1985 Chevy Camaro
Axle/Gears: 3.08
tbi heads?
ok so i bought a 305 pan to intake. only 100 bones i viewed it running in a car about 4 weeks ago so i know it runs. he deal is i didnt pay any attention, and i think it might have run tbi. the heads are those stupid "187" swirl heads and i am wondering if those tbi swirl heads mean that i cant run it carburated? i really dont know
Axle/Gears: 3.08
Re: tbi heads?
well i just found a thread on tbi to carb but it didnt really answer the question fully. can i swap the q-jet and distributor from my stock 305 to this that is centerbolt newwer 305 and be able to run it? or is that just to easy and im actually gonna need more parts and money
Re: tbi heads?
The 1987 lg4 and 1987 carbed 350s have a bolt up intake that will work, but your stock pre 87 can be modified to work also. One side of each of the four center holes in the intake need to be slanted outward to line up with the angle on the 87-up heads. The bottom of the hole is in the same location.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: tbi heads?
Buy an intake with the "87+" bolt pattern and it will fit just fine.
Transmission: 4L80E/4L80E
Axle/Gears: 3.08
Re: tbi heads?
it has to be stupid easy if im gonna do it but no worrys about the tools i have all i need. is it even worth the effort in the long run when compared to my stock 1985 lg4? i think the vin code on the motor is H. will i be able to run all my stock computer stuff and stock q-jet from the 85 motor with just a intake change or mod?
Or put your LG4 heads on the "new" 305. Then everything will be hunky dory.
But, either way, the LG4 stuff won't have any problem with it. It doesn't have any problem with my 350 (see my vBGarage for details).
Axle/Gears: 3.08
Re: tbi heads?
am i actually getting any better with the newer 305 and older heads or am i wasting my life away making the swap? just a couple of years make a difference when it comes to engine blocks when they are both 305's ?
evilstuie
Jan 9, 2020 08:29 PM
