350 Swap issues
Old Feb 26, 2009 | 04:18 PM
92whiteta's Avatar
Car: 86 WS6 Firebird
Engine: 355
Axle/Gears: 2.73 open
350 Swap issues
i just finished my 350 swap. the motor idles a little rough it revs up well it has 18 inches of vacuum and it sitting at 6 degrees of timing. the problem is the engine has no power it wont move out of its own way. and i have to set the idle at 1000 RPM so it wont die when i put it in gear. No check engine light is on it starts up just fine. the engine is in my sig. and i did swap in the entire 350 ecu with 350 prom. the only thing i can think of is maybe i have to advance the lt1 cam by one or 2 teeth? and suggestions would be great.. i am running out of ideas for this one...
Old Feb 26, 2009 | 06:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check your spark plug wires. Might have a couple of them switched.
Old Feb 26, 2009 | 08:23 PM
92whiteta's Avatar
Engine: 355
Re: 350 Swap issues
i checked them twice since putting them on. i restabbed the distributor and it is alot better but there is still something wrong.. i will check the wires again but i am sure they are right.
Old Feb 26, 2009 | 08:37 PM
five7kid's Avatar
I've gotten them crossed myself. Figured it out by taking them all off and starting from scratch.
But, if you're confident they are correct, check the cap & rotor, and pull the plugs to see if any obviously aren't firing correctly. Switch good & bad between cylinders to see if it follows the plugs or the cylinder.
Frozer!!!
Jan 19, 2024 04:55 PM
xkingcodex
Feb 12, 2020 07:43 PM
bellez77
Sep 5, 2015 08:39 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
