If I Swap in a 455, Will I?
I just want to know, what bolt engines are on the '91 Camaro RS (V6 Engine), I'm assuming 4 bolt?
Also, since the 455 is one extremely old engine and doesn't use engines, could I keep the same wiring harness on my Camaro? But I don't know how the old engines work...What would I need to end up doing?
Transmission: 4L80E/4L80E
"4-bolt" refers to the number of main bearing cap bolts. Doesn't have anything to do with how the engine is mounted in the car.
A 455 is either a Pontiac, Buick, or Olds engine. They are all different. There is a sticky in the top section of this forum about installing a Pontiac engine. Otherwise, you're pretty much on your own fabricating what it would take to install one.
Replace? No.
Modify? Without a doubt.
Read through the sticky.
Hello, Michael
Aug 20, 2015 03:19 PM
