350 swap
Old Mar 2, 2009 | 01:04 PM
90/81camaro's Avatar
Car: 1992 RS camaro
Engine: 383
Axle/Gears: Stock
350 swap
I'm rebuilding a 350 to put in my camaro and the block came out of an 81 camaro, I was wondering if I put a new cam in if I would have to get new pistons.
Old Mar 2, 2009 | 01:09 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
Re: 350 swap
No you won't need new pistons just because you're putting in a new cam but if you bore out the block you will.
Old Mar 3, 2009 | 12:42 PM
Car: 1992 RS camaro
Engine: 383
Axle/Gears: Stock
Re: 350 swap
thanks. i just wasn't sure because of the compression. And i have another question, the gear ratio that the cam calls for is 3.73 or higher and i don't really know much of anything about the rear end so how would i change the gear ratio?
Old Mar 3, 2009 | 01:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
With a low compression engine, you don't want a cam with too much overlap. So, don't go hog-wild there.
The gears aren't directly tied to the cam selection. It's more of an overall performance indicator, particularly 1/4 mile. But, to change the gear ratio, you need to change the rear end gears. Which requires special equipment and skill, so it's typically best left to a shop. The Transmission and Driveline forum will have more information about gear changes.
Old Mar 3, 2009 | 01:30 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: 350 swap
Requires a new ring and pinion set in the rear end.
xkingcodex
Feb 12, 2020 07:43 PM
bellez77
Sep 5, 2015 08:39 PM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
