Flywheel
Old Mar 17, 2009 | 07:08 AM
richfield's Avatar
Flywheel
I am putting a 350 into an 86 Trans Am. Am having Flywheel/starter/torque converter issues. The 350 has a larger flywheel so my starter and torque converter dont match up. Can I use the 305 flywheel? I have heard that there are balance issues. Do they make a 153 tooth for a 350? If I use a smaller flywheel on the 350 do I use a stock harmonic balancer?
Old Mar 17, 2009 | 07:51 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Flywheel
first, the later engines with 1-piece rear main seal used a balance weight on the flywheel (manual trans) or flexplate(automatic trans). second, Chevy also changed the bolt pattern on the crank. Early flexplates stay with early engines, late flexplates stay with late engines. Now, the late 305 and late 350 can interchange flexplates. The late flexplates were offered in both 153 tooth for F-car, and 168 tooth for fullsize pickups. Or you can change your starter and torque converter. In any case, leave your 350's damper alone. The earlier flexplates were also offered in both 153 and 168 tooth versions.
Old Mar 18, 2009 | 06:49 AM
richfield's Avatar
Re: Flywheel
Thanks for the answer. I thought that might be the case but wanted to make sure.
Old Mar 18, 2009 | 08:37 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Flywheel
Thanks for the thanks. So many people just don't appreciate the help enough to say so, then who wants to help them again?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
