Heres my plan. Missing anything, or anything wrong?
Old Mar 26, 2009 | 10:45 AM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
right now i have the 305 in my 84 Z28. i have a 350 block bored .030 over.
im looking at some engine kits to put in.
there is this one
http://store.summitracing.com/partde...0&autoview=sku
and along with that, here is the top end kit im looking at
http://store.summitracing.com/partde...5&autoview=sku
in addition with those i plan on putting SFCs, i got an aluminum driveshaft. i have 3.73 gears with a posi waiting to be put in.
i'll be running a dual exhaust of course. i found cross-members from summit that allow a dual exaust to go through easily, though i just looked at it and it didnt have any for third gen F-bodies. they did however for G-bodies.
oh and what kind of carb should i run?
are there any other things that i'm missing? i know there are many other small things that i need to get. but do those kits seem to be fine and am i on the right track?
Old Mar 26, 2009 | 10:47 AM
Convoy25's Avatar
Re: Heres my plan. Missing anything, or anything wrong?
oh i forgot to add, i heard about those transgo kits, and i'll look more into those. i might want to add that to the plan
Old Mar 26, 2009 | 11:57 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You could do that. But since you're buying a crank and pistons, why not do a 383?
Old Mar 26, 2009 | 05:09 PM
Convoy25's Avatar
i was thinking about that, but dont i have to get some machine work done to the block for that? i thought it did and it would be like 400-500 bucks
Old Mar 26, 2009 | 05:13 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
to get a 383 all you need to do is bore 30 over and get a 400 crank. you already said you bored ir 30 over right? all you need is a crank
Old Mar 26, 2009 | 05:23 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
There will be some slight clearancing to do at the bottom of the cylinders and the pan rails, but you can do that for almost free.
Old Mar 26, 2009 | 06:16 PM
Convoy25's Avatar
how big of a difference in gas mileage would there be from the 355 to the 383?
Old Mar 26, 2009 | 06:22 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Considering that TFS top end kit you're considering, it could work out equal, depending on your choice of axle ratio. At worst, 3 mpg less.
Old Mar 26, 2009 | 09:51 PM
Convoy25's Avatar
would it still be able to be my daily driver? (the gas mileage isnt that big of a factor)
Old Mar 26, 2009 | 09:57 PM
Nub383's Avatar
Car: 94 Silverado
Engine: 383 Vortec TBI
Transmission: 4L60
383. Do it! Watch your oil pan rails. You can clearance your block yourself, its easy. Have you bought these parts already?
Old Mar 26, 2009 | 10:06 PM
Convoy25's Avatar
no right now im saving up. i plan on buying the SFCs sometime soon. i plan to build the engine in the summer. thats when i'll have a large flow of money because i'll have my one job + lifeguarding in the summer.
i already have the stuff for the rearend in my room and the driveshaft on the way.
i just wanted to know if i was on the right track so i knew where to put my money.
but like i said, if i do the 383, will i be able to have it as a daily driver? not so much on the gas end i mean.
oh and my friend thats also building a 383, said the machine work for the block was about 200 bucks
Old Mar 26, 2009 | 10:15 PM
Nub383's Avatar
Car: 94 Silverado
Transmission: 4L60
There are guys that are running 383s that say they get better gas mileage. Mine is about the same as my worn out 350. Tune it right and you will be happy. Clearancing the block is easy. Trust me. You can do it.
Old Mar 26, 2009 | 10:25 PM
Ca[maro]88's Avatar
yeah it would still be a daily driver. like he said though your axle and gears will help determine your fuel milage. go for a 383. it just sounds better
Old Mar 27, 2009 | 02:04 AM
Nub383's Avatar
Car: 94 Silverado
Transmission: 4L60
That rotating assembly that you are thinking about at Summit is like $859. My rotating assembly is an eagle for a couple hundered more. I had my block machined at a machine shop and I spent an hour or so clearancing it for that bada$$ crank. I used a drill with a stone, a zip tie, and looooots of carb cleaner. I bought a small base grind cam from comp with matching lifters because I didn't want to notch my rods. I ran vortec heads so we won't even get into all that. The shortblock didn't even take half a day to put together. It kinda depends on what you want that car to do for the cam you want though. If you go with a small base grind, make sure to use a pushrod length checker because you probably won't be able to go with stock length. It's a torque MONSTER!
Old Mar 27, 2009 | 07:58 AM
Convoy25's Avatar
im convinced.
a 383 it shall be
92firebirdguy
Sep 1, 2016 07:53 AM
devilschariot
Feb 25, 2016 03:08 AM
Dyno Don
Jan 24, 2016 08:24 AM
L98GTA87
Oct 19, 2015 10:43 PM
BLK87Z
Sep 18, 2015 11:29 PM
