please help me
Car: 1985 Camaro
Engine: 305 ci
please help me
I'm lost. I found a 99 Suburban in near perfect condition w/o a title for $1000. It has the 5.7 vortec engine and a 4l60e transmission, but I don't know if i could use that transmission in my 84 camaro. If so will I have to do any modifications for it to work? I asked this in the transmission subforum but thought i'd post it here since it's pertaining to a lsx swap. thanks you guys
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Re: please help me
only 5.7 is ls1
a 5.7 vortec is a sbc. ur truck is not lsx,
the trans is diff., since fbody use tq arm mount trans.
but u will be able to adapt the engine to your trans.
Transmission: 4L80E/4L80E
If the Suburban is 4 wheel drive, you would have to convert the transmission to 2 wheel drive, which involves a total disassembly.
If it's 2 wheel drive, you need the torque arm mount on the output shaft housing, or provide some alternate means of mounting a torque arm.
Yes, a '99 Suburban will have a Vortec engine, but that doesn't make it LSx or LTx. It's a Gen I type engine.
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Re: please help me
The 5.7 Vortec will bolt right up to what ever transmission is in your thirdgen, as long as you have a V8 in it already. Otherwise just find a 700R4 to use!
Car: 1985 Camaro
Engine: 305 ci
Re: please help me
ok thanks. i was badly mistaken about the engine. i guess it was too good to be true and i will pass on it and save my money until i get a lsx swap into my cammy. thank you guys for your help. sorry to bother you.
No bother at all. Just setting the record straight.
And for what it's worth, it sounded like a good way to go to me. But, only as a Gen I Vortec swap. If you're looking for an LSx swap, you need to go 2000 or later if it's a truck.
Car: 1985 Camaro
Engine: 305 ci
Re: please help me
thanks for setting that straight for me because i was thinking that the 99 trucks had it. lol. that shows how much i know. I was WAY too excited, but that's how you learn.
