Radiator Coolability
Car: 1992 Rally Sport
Engine: 355CI
Axle/Gears: 10bolt stock gears
Will my Stock Radiator for my 305 tbi rs be enough to cool my 355?
Or should i up grade my radiator?
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Radiator Coolability
You'll likely be fine with the stock radiator, provided it and the rest of your cooling system is in good shape (and your new motor runs a good state of tune). So...
Yes/No
Yes/No
Transmission: 4L80E/4L80E
The factory used the same radiator for the 305 and 350, and even the 3.1 V6. It doesn't "need" to be upgraded. But, it won't hurt anything except your wallet to do so.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
As long as the core tubes are not plugged and the fins are in good condition to remove the heat then it will have no problems.
