305 tpi to 350 carb HELP
Car: 1990 Camaro IROC-Z28
Engine: 5.7L 350cid
Transmission: auto
Axle/Gears: i think 3.42
what is involved in doing this i took out the 305 and im looking to buy a 350 and i wan an old look all mechanical so what do i do about the fuel pump and stuff i need help from some one who did this thanks i need step by step help as well
Transmission: 4L80E/4L80E
Pretty much documented in the EFI to carb swap tech article. Except the changing of the actual engine.
Engine: 5.7L 350cid
Transmission: auto
Re: 305 tpi to 350 carb HELP
cool thanks do you have some kind of link for that ? and how hard is it do do it
From the thirdgen.org homepage, on the left margin is a "tech articles" link. Click on that, look for the article on the conversion.
Or, on the Carburetor forum, there is a sticky "welcome to the carb forum" that has a link within it.
Engine: 5.7L 350cid
Transmission: auto
so pritty much get a afpr and a carborated 350 and thats it ? i dont have to worry about anything els ?
Nope.
Except adapter fittings.
And different fuel lines.
Different length throttle cables.
Different distributor.
Different thermostat housing.
Different upper radiator hose.
Different TV cable geometry.
Different air cleaner.
Needing some means to lock up the torque converter clutch.
Being completely illegal for use on public streets, roads, highways, and byways by Federal emissions requirements.
Other than that, all you need is a return-type fuel pressure regulator.
Sanjay
Aug 12, 2015 03:41 PM
