383 first fuel tpi crate engine on the way!
Old Apr 7, 2009 | 10:43 PM
73duster's Avatar
The 383 first fuel tpi engine i had built is on route! I ordered it from a place called precision auto machine in tennessee. It's got pro comp aluminum heads, 10.5 to 1 compression and is topped off with the first fuel setup. The motor also comes with distributor, 24# fuel injectors, pressure regulator and complete wiring harness including computer with ready tuned chip for the cam. Also forgot it comes with external mounted fuel pump. I already ordered a walbro in tank that i'll use instead. The motor should get to the shop by the end of the week. Hopefully everything will be up and running by sometime next week. I will try to take pics after everything is done. They also broke in the motor and dynoed it. Adam from precision auto machine told me that they ran it a couple of times and each time it made more power and ran better as the computer will tune itself further. I think he said it was making about 386 hp but should end up over 400 after i drive it for a while. That's exactly what i was hoping for. The engine was $6,000 and delivery 275. Not bad for everything thats included.
Old Apr 7, 2009 | 10:50 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: 383 first fuel tpi crate engine on the way!
Looking forward to the pictures.
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
