fitment question
Old Apr 9, 2009 | 01:40 AM
rock861261's Avatar
fitment question
i have a 78 350 from a corvette in my truck and am about to do a ls1 swap into my 91 camaro my question is if i take the heads from the camaro will they fit on the 78 allowing my manifold to fit and run the tpi setup?
Old Apr 9, 2009 | 01:53 AM
92RSStud's Avatar
Car: 1992 Rally Sport
Engine: 355CI
Axle/Gears: 10bolt stock gears
Re: fitment question
you wanna do what now?
I got out of this.. ls1 swap... heads and manifold from old motor onto the ls1?
The heads will fit.. and the manifold with fit on the heads as long as they are not vortec heads... but why would you wanna run older heads on a newer motor.. if your gonna swap in an ls1 i'd use the heads off of it. Much better.
but dont take my tech as 200% true... i could be wrong. wouldn't be the first time.
Old Apr 9, 2009 | 03:03 AM
rock861261's Avatar
lol no my friend
taking the tpi from my 91 camaro and want to use it in my 78
im going to put a ls1 in my camaro
just want to know if the tpi heads and manifold from the 91 will work on the 78
Old Apr 9, 2009 | 09:18 AM
92RSStud's Avatar
Engine: 355CI
should.
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
kah992
Aug 19, 2015 02:55 PM
redmaroz
Aug 16, 2015 11:40 PM
