83 camaro 305-350 engine?Advice+
Old Apr 26, 2009 | 07:33 AM
morellimd's Avatar
Car: 83 Z28 Camaro+95 Pontiac Firebird
Engine: 305+3.4L V6
Transmission: 700 R4 w/ Shift Kit
Will i need to get an older year engine to fit in as easy as people say they will. Ive been looking for a car with a 350 in it to take out rebuild if necessary and get the mounts and install, I new advice on what steps to take and how to approach the situation by Year, Make, and Exc. Thanks to all who Help!
Old Apr 26, 2009 | 11:12 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 83 camaro 305-350 engine?Advice+
Your 350 does not need to come from another Camaro/Firebird. after '79, most 350s were installed in pickups. You can use a 350 from '74-'79, with the driver's side dipstick. For '80, GM moved the dipstick to the passenger side, and changed the oilpan. So the '80-'85 blocks are the most similar to what an '83 should have. For '86, GM changed the blocks, cranks, oilpans and flywheels/flexplates to allow the new 1-piece rear main seals. This drastically reduced warranty claims for oil leaks. Then for '87, passenger car V8s got rollers added to the lifters. All the SBCs got new centerbolt valve covers with the heads revised to match, for '87, and the angle of the 4 center intake manifold bolts was revised, except for the 'vette. You do have an easier option. Spend around $1600 for an all-new-parts, including block, Goodwrench 350 directly from GM, part number 10067353. It's a direct bolt-in for you, just transfer your mounts, manifolds and accessories from your 305. It can't get any simpler to go to a 350.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
