ANOTHER 305 to 383 SWAP QUESTION
Old Apr 26, 2009 | 07:28 PM
88_TeenTrans's Avatar
Car: 1988 Fire Bird (T-Roof)
Engine: 5.0L 305 TPI
Hey im planing on swapping my 305 TBI to a 383 stroker. Im planing on using as much of the orignal stuff off my 305 I can (wiring harness) is this possible? I heard I would be able to go find a different ECM that was in..I cant remember that had a 350 TBI setup. I WILL be changing the injectors in my TBI unit and the fuel pump no way that stuff from my TBI would hold its own for a 383. BUT what else will I need to adress??? I live in ontario so I still have to put up with the dam POLLUTION *****.
FEEL FREE TO LEAVE STEP BY STEP HOLD MY HAND WALK THRU =D
Old Apr 28, 2009 | 08:32 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
Re: ANOTHER 305 to 383 SWAP QUESTION
you shouldnt have to change your fuel pump mine works great
what are you emission laws like can yo swap a carb on to it like i did
the problem with changin injectors is you not only have to provide more fuel but the air also
i used a lot of my factory stuff like my sensors but other than that i kinda tossed it out the window
well ask if you have more questions hope i can point you in the right direction
zig
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
reiderz iroc
Aug 13, 2015 04:57 PM
