305-350 in alaska
Old May 24, 2009 | 02:48 AM
Derrack's Avatar
Car: 1985 Camaro Z28
Engine: 305, 4bbl looks stock
Transmission: T5, looking to upgrade
305-350 in alaska
i have an engine out of 78 fire bird. VO22OCHT it looks like a 1 piece rear main. will this fit up to a t5 in a 85 camaro? since the 305 in it is a two piece would i not be able to use it? could i use the same distributor thats in the 305 and would the exhaust bolt in or would i need to get some headers *plan two anyways and take the smog pumps out/egr imissions stuff* whitch would fit? my engines tired and blowing some blue smoke. what problems will i run into? what do i need to do/buy to make the project smoother than it would otherwise be and get the car on the road again? most of all is this engine a waste of time/ not compatable because of the year/main?
Old May 24, 2009 | 09:26 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: 305-350 in alaska
As long as it is a small block chevy, everything will swap out. If it is a one piece rear main and the old motor is a 2 piece, you will need a different flywheel.
87TAinAK
Apr 29, 2006 02:16 PM
84 t/a 5.0
Dec 8, 2005 10:34 PM
Crusader
Pacific Northwest Region
Apr 28, 2001 09:34 PM
