Starter for 5 speed w/ 305 - Which years fit? All?
Old May 29, 2009 | 01:42 PM
westman995's Avatar
Car: 1982 Trans Am
Engine: 350 Chevy
Axle/Gears: Stock
OK i have an 82 TA, its not got a 5 speed out of an 84 Camaro in it, the motor is an older 350 sbc.
I got a starter from the junk yard for an 87 camaro, i figured it didnt fit as it didnt quite go into the bellhousing, but i didnt play wtih it i just saw it not go in and brought it back. Im starting to think i should have played with it a little more.
Are the 84-87 supposed to be the same starters for the camaros? I figured they would be, but i need a definite answer, ill prolly go back and get that starter if it should work.
EDIT: The title should have been 350 not 305, not that that really matters. And also the starter would have bolted to the block so that wasnt the problem, just the hitting the bellhousing.
Old May 29, 2009 | 02:13 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Starter for 5 speed w/ 305 - Which years fit? All?
There is some variation in the nose cones of stock-style starters, and you could also have this problem if you're trying to use a 168-tooth flywheel with a T5 using the T5's stock bellhousing. T5s only came with 153 tooth flywheels.
Old May 29, 2009 | 02:54 PM
westman995's Avatar
Car: 1982 Trans Am
Engine: 350 Chevy
Axle/Gears: Stock
I am using all stock parts from the camaro, its the smaller flywheel, so its gotta be the 153. All the parts came off the same car minus the engine. So the tranny, flywheel, clutch etc all came together, the car i used for parts did not come with a starter tho so unsure how to find one that fits.
Old May 29, 2009 | 07:15 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
You MUST use the T5 starter from a 84+ T5 car OR a 93-97 camaro with the T56 6 speed(lt1 car).
Old May 29, 2009 | 07:17 PM
westman995's Avatar
Car: 1982 Trans Am
Engine: 350 Chevy
Axle/Gears: Stock
So, with that said the starter off that 87 Camaro should have worked? It had the straight bolt pattern on it if that signifies it being off a 5 speed?
Pac J
May 17, 2020 10:44 AM
Lbibb
May 5, 2016 12:00 AM
Fireslash
Apr 11, 2016 06:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
Formula_88AE
Sep 3, 2015 01:47 PM
