Header to Fuel Line Clearance
Old May 31, 2009 | 01:21 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I just dropped my rebuilt 350 into my Camaro. I'm swapping from a 3.1 and the header on the driver's side is very close to the fuel line. How much clearance should there be to prevent the heat from the header causing a fire? I have maybe 3/8"-1/2" now. I hate the way heat-wrap looks, but if it will help, I'll use it. Since it's hard to explain in words, pics are below.
Attached Thumbnails Header to Fuel Line Clearance-dsc01204.jpg   Header to Fuel Line Clearance-dsc01205.jpg   Header to Fuel Line Clearance-dsc01206.jpg
Old Jun 1, 2009 | 09:30 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Header to Fuel Line Clearance
undo a few of the screws holding the lines to the subframe, then hand-bend the lines at least an inch away.
Old Jun 1, 2009 | 10:07 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Thanks. That's what I was thinking. I just wasn't sure how far apart they needed to be.
Old Jun 1, 2009 | 10:13 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
also move the brake lines if need be.
Old Jun 1, 2009 | 10:14 AM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
you definetly dont want your brake fluid to start boiling.
Old Jun 1, 2009 | 10:46 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
The brake lines should be ok. I believe they are all at least an inch away from the header, but I'll double check them tonight. I'm planning on breaking the engine in on Wednesday, my main concern was not having an engine fire from the fuel lines being too close to the headers. Especially since my garage is under my house.
Old Jun 1, 2009 | 01:39 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Make extra sure your upper radiator hose is really secure, I had ine come loose, and a half hour later I was in the ER getting my second dose of Morphine for my new second-degree burns all over my face, neck and chest. It was a new hose with a new chrome water neck. No more chrome for me.
Old Jun 1, 2009 | 02:29 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
I haven't put the radiator back in yet, but I'll definitely check that. That doesn't sound like something I want to do. I'm reusing an old water neck with new clamps so hopefully the corrosion on the neck will help keep the hose in place. Hot coolant will be almost as bad for the house as an engine fire.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
mdtoren
Aug 23, 2015 12:52 PM
AkDrifted
Aug 17, 2015 07:45 PM
