TPI QUESTION
Old Jun 5, 2009 | 09:03 PM
89RSCAMAROMAN's Avatar
Car: 1989 Camaro rs
Engine: TBI 305
Transmission: t5
Axle/Gears: 3.08
TPI QUESTION
Will the T.P.I setup work on a 400 small block? The Tpi setup came off a gta firebird with a 350 i believe. Also do will i still be able to use the wiring harness that came from the firebird. I have a 89 Camaro. please help thank you Brian
Old Jun 6, 2009 | 11:57 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
What year?
Old Jun 6, 2009 | 05:03 PM
Car: 1989 Camaro rs
Engine: TBI 305
Transmission: t5
Axle/Gears: 3.08
Re: TPI QUESTION
i believe it was a 87-90 one of them years
Old Jun 6, 2009 | 11:23 PM
five7kid's Avatar
'85-'89 had a mass air flow sensor to determine fuel, spark, etc. '90-'92 were "speed density" or "manifold absolute pressure". MAF is more adaptable but flow-limited. SD is more capable but requires more tuning.
TPI will "fit" a 400, but will severely limit power. An aftermarket system like the Holley/Weiand Stealth Ram frees up flow and power. Combined with a SD system, you can make good power and retain the benefits of EFI.
If your Camaro isn't TPI, you won't be able to use any of the computer-related harness (without extensive modification). The rest of your harness (alternator, gauges, ignition power, etc.) will be fine.
Old Jun 7, 2009 | 06:53 PM
Car: 1989 Camaro rs
Engine: TBI 305
Transmission: t5
Axle/Gears: 3.08
Re: TPI QUESTION
I guess i Would be better going with a 350 huh?
Old Jun 8, 2009 | 02:21 AM
five7kid's Avatar
Not necessarily. Most of the problems with TPI on a 400 exist on a 350 as well.
Old Jun 8, 2009 | 10:40 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: TPI QUESTION
A local guy has a 406ci SBC with Trick Flow heads and an Accel SuperRam, and he made 403 RWHP and 450 or so RWTQ. I'd say with the right setup, a 400ci engine can work with a TPI just fine. But not a stock TPI intake, no way.
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
