91 RS 305-383 carb tach wont work
Old Jun 16, 2009 | 06:29 AM
383 stroker 91's Avatar
Car: 91 RS
Engine: 383 Stroker 010 high nickel
Transmission: built 700r4
I just did a conversion if anyone has questions about it. Now that is use a HEI distributer instead of the comp controled my tach operates strangely at about 5000 at idle. Anyone have any ideas. My car is now carbed and uses no comp.
Old Jun 16, 2009 | 01:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The computer controlled and non-computer controlled tach outputs are the same - just the coil trigger signal. Does the tach go down to zero when the ignition is off?
Old Jun 17, 2009 | 10:27 AM
Car: 91 RS
Re: 91 RS 305-383 carb tach wont work
Yes it does go to zero and it goes down slightly when in gear also but not enough. I seen some adaptors on summit but wanted to see if there was a easy better way.
Old Jun 17, 2009 | 01:59 PM
five7kid's Avatar
Are you using an aftermarket ignition box?
Old Jun 18, 2009 | 06:23 AM
Car: 91 RS
No it is just the HEI distributer from summit which i think is a malory distributer but no box. I followed the directions of a sticky i think and there they didnt have a tach problem.
Old Jun 18, 2009 | 02:21 PM
five7kid's Avatar
Hmmm, I'm drawing a blank. You have the white wire connected to the "TACH" terminal, correct?
How does the tach act at higher RPMs?
Jeremys87
Jul 14, 2022 09:08 PM
midge54
Dec 27, 2019 04:14 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
