Started my 2.8 to my 305 swap today
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
Well i started my swap today and what a pain to get the v6 out..This was done in my front yard with two trees a chain and a come-a-long..I pulled motor and tranny together to make it easier. The exhaust was a problem.Ended up taking the exhaust manifolds off to get it to come out..didn't know a v6 had 2.5 inch pipe off the exhaust let alone double wall pipe..here a some pics of what i did today..will move motor mounts tomorrow and clean up engine bay a little.I will try to get better pics tomorrow and replace these.
Engine: 350 crate
Re: Started my 2.8 to my 305 swap today
can anyone tell me the easiest way to get the bottom bolt off the motor mount on the frame
Engine: 350 crate
well my plans were changed on my 305 swap..i ended up selling my t5 tranny for 400 and bought a crate 350 with it from a guy down the street...little did i know that the 350 i got wasn't a 350.pulled the clutch and flywheel off sold it too and went to put my 305 flywheel on it and would not fit...got to lookin and the flywheel hole i needed was much bigger and had an external balance on it"crank"..turns out it is a 400 crank..so i got a stroker motor with 3600 miles on it for 400 bucks..i will put some pics up in the morning
Engine: 350 crate
still have my 305 if anyone needs parts off of it fresh rebuild never turned over
Transmission: 4L80E/4L80E
Different size hole and weight on the flywheel doesn't mean 400 crank. The pictures may shed some light, but you can't necessarily tell stroker from the outside.
Engine: 350 crate
i know five7 it doesn't mean its a stroker...i got in touch with the original owner of the motor and he had it in a mud truck...he said the 350 was not enough for him so he got a stroker kit for it...he got a crank with an external balance which would explain why my flywheel wouldn't fit it..he is getting a parts list for me for what he put in the motor so i can keep the waranty on the new stroker kit he put in it...i know i need to clean it up a little ..gonna put the fuel lines on it tommorow and hook up my wiring harness and fire it off
Engine: 350 crate
i need some help with a wiring issue..for the windshield wiper motor..my harness from a 91 bird is different than the one for the 2.8 v6 i can't find the plugs for the wipers..every thing else i have found..someone please help me out with this
Engine: 350 crate
well i got my motor and tranny in but ran into a little snag..i have to use the v6 wiring harness because the windshield wipers were on the main harness and the v8 it is different..here is the prob it use to be a 5 speed man..now it is a 700r4..i need to know how to hook up the lock up on it..it still has the plug for the speedo which will fit but the other plug won't i have a plug that will fit it though.how would i do this..
if someone could show me a diagram it would be great..not that good when it comes to reading about it..got that a.d.d crap and i get side tracked easy..
92camaroJoe
Aug 13, 2015 06:07 AM
