350 + T56 Build/Swap
Old Oct 20, 2011 | 01:52 PM
  #51
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: 350 + T56 Build/Swap
i was running the vortec air gap on the stroker before i pulled it with the same aircleaner and 3" filter. i wasnt running a spacer at all though. and i think my air cleaner was actually just barely touching the hood bracing.
Old Nov 7, 2011 | 01:47 PM
  #52
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
Do you have a part number for the flywheel you used.
Old Nov 7, 2011 | 02:37 PM
  #53
plasmeh's Avatar
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
Centerforce 700107 - It's for 2 piece rms blocks with a LT1 T56. Costs $429 from summit.
angel2794
Sep 8, 2015 06:22 PM
Eric-86sc
Aug 24, 2015 09:01 PM
86iroc z Z28
Aug 21, 2015 10:37 PM
sreZ28
Aug 14, 2015 07:48 PM
BBSDesigns
Aug 11, 2015 07:39 PM
