Swap 1990 TPI Iroc 305 engine with 350
Old Jun 17, 2009 | 11:24 PM
cohranspeedy's Avatar
I was looking at two different ways to go about having my car running good. I bought a rebuilt motor for my 79 Chevy Truck but never used it and now I was trying to figure how hard it would be for that 350 four-bolt main to be installed into the 1990 Iroc with the TPI 305. I'm trying to keep TPI, is that impossible? If not, does anyone have any ideas on how that is done?
I was going to buy a new engine and drop it but I want the most horses with the closest to stock look.
Thanks,
James Cohran
Old Jun 18, 2009 | 12:31 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
It can be done. If the engine was a direct replacement for a '79 truck, you'll have a few things to work around. The '79-earlier engines had the dipstick on the driver side; if you keep you stock exhaust manifolds, the dipstick tube and manifold try to occupy the same space at the same time (headers solves the problem). '85-earlier had a two-piece rear main crank seal, and your '90 has a one-piece - you'll need a different flexplate (not a biggie, just a detail). '86-earlier heads had all of the intake mount bolts at the same 90 degree angle, while '87-later (cast iron) heads have the center two intake mount bolts on each side at 72 degrees. Your '90 TPI base will either have to be replaced with an '85-'86 base, Corvette base, or modify those bolt holes in the base so you can get the bolts in.
Truck heads usually weren't very good from a performance standpoint - small valves (poor flow), large chambers (low compression), crack prone, and generally just don't run well. Your current 305 heads are a better choice. With 1.94" intake valves installed, and assuming your 350 has dished pistons (pretty strong likelihood), better compression, and the above TPI base problems now go away.
You will also either need to get a 350 computer chip, or have your 305 chip reprogrammed for the 350.
You'll also want to get 350 injectors.
Other than that, piece of cake!
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
