Yearone Vortec headed Power Crate
Old Jun 22, 2009 | 02:27 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
I was looking for some information on this engine and was having difficulty finding it. I emailed Yearone and got the following response. I thought I would share the information with you. I was just about to buy an L31 block ($2200) swap the heads for patriot vortec (cost me about $130 after I sold the old heads), change the Cam and install a comp XR270 or XR276 ($250), and add then intake manifold ($185) and flexplate ($100) plus the cost of Misc bolts and gaskets.
http://www.yearone.com/serverfiles/f...ain2.asp?cat=G
Thank you for your interest in Year One products. The intake manifold is usually a Cross Wind by Pro Products. The cam is a custom specified grind, manufactured by Cam Machine Co (The cam has .520 lift and 112 deg LSA. The duration at .050 is 218 and 228) . This uses standard flow cooling and the block is 1 piece rear main seal.
I hope this helps.
The engine is Dyno tested and comes with a 12month/ 12k warranty and looks like it essentially comes with a LT4 hot cam, has a slightly higher CR than the L31, and is a 4 bolt main instead of a 2 bolt. Anyone have any opinions on this as it seems like a pretty good deal.
Old Jun 29, 2009 | 02:38 PM
THETANK's Avatar
Car: 91 rs
Re: Yearone Vortec headed Power Crate
Some additional information I located on the engine for anyone else that may be interested in the same engine.
http://forums.corvetteforum.com/c3-t...e-install.html
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
