removing the 305
Old Jun 23, 2009 | 04:03 PM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
removing the 305
I am in the process of removing the 305, all I have left is removing the exhaust then I should be able to unbolt the motor mounts and lift out the engine. My question is where is a good point to bolt up the chain for lifting out the engine? I noticed a hook on the front of the engine but did not see a place in the back.
Thanks for the help!
Old Jun 23, 2009 | 04:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I usually pull a rear corner intake manifold bolt and put a longer one through the chain, or if I'm feeling up to it, use one of the bolt holes on the back of the head.
Old Jun 23, 2009 | 05:00 PM
mgilorma's Avatar
Car: 90 RS
Re: removing the 305
Thanks for the tip, I've never pulled an engine before, but hopefully this weekend that will change!
Old Jun 24, 2009 | 11:08 AM
mgilorma's Avatar
Car: 90 RS
would you recommend an engine load leveler? As of right now I have the tranny removed, but left the bell housing attached to the engine. I will be using a celing hoist.
Thanks!
Old Jun 25, 2009 | 12:39 AM
five7kid's Avatar
They usually help in the process. Mine is a little too long and gets in the way of the cowl lip. My brother has a shorter one that doesn't have that problem.
Old Jun 26, 2009 | 07:19 AM
mgilorma's Avatar
Car: 90 RS
I got the engine out last night, the engine leveler definetly helped. Also my engine actually had another hook on the back of the engine, so I just bolted the engine leveler up to those hooks and it went about as smooth as it could since I was doing it by myself.
Thanks for the helpful advice!
Jake_92RS
Jan 28, 2020 10:37 PM
theurge
Aug 21, 2015 12:46 PM
kyleb24
Aug 15, 2015 08:24 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
