Serpentine bracket question
Old Jun 28, 2009 | 04:01 PM
protek25's Avatar
Car: '84 Z28
Engine: Building 383
Axle/Gears: 3.73 Posi
I was wondering which one of the serpentine systems would/would not fit my 1984 Z28. I'm doing a complete rebuild, as it has turned out, and I'd like to eliminate that WAY complicated array of supports, and brackets from the V belt system. I'll be keeping the AC, and would even consider using the newer, smaller diameter style AC pump, if it can be made to work/fit. I also won't be using the A.I.R. pump, and would like to be able to use one of the bracket that doesn't include a spot for this, though I'd use the other is necessary. Mainly hood clearance seems like it'd be the problem. I know that I want nothing to do with the TPI setup....looks kind of like a mix and match with Aluminum and steel support.
Old Jun 28, 2009 | 04:23 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Serpentine bracket question
The following link may provide some ideas:
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
Old Jun 29, 2009 | 12:12 AM
protek25's Avatar
Car: '84 Z28
JamesC
The links were great! Thanks. However, I wonder if you know whether or not the passenger side bracket from, I think, a pick-up truck with the larger air conditioning pump puts the air conditioning pump in the same position as the other bracket with the smog pump mounting included. The truck bracket is lots cleaner looking, and leaves the area around the fuel pump open. I know it is ****, but the smog pump version looks like something got left off. As for the rest of the questions, it does appear, after looking at all the pictures, that except for little pieces of hassel, everything will fit in the Z without hitting any body parts, like the hood. Yes?
By the way, Neitzsche was a pretty dark guy, and not all convictions are lies, or even half truths. Unfortunately, they have to be searched out, and don't lend themselves necessarily to clever turns of phrases.
Old Jun 29, 2009 | 07:31 AM
JamesC's Avatar
Originally Posted by protek25
I wonder if you know whether or not the passenger side bracket from, I think, a pick-up truck...
The manual for my 350/330 advises using accessory brackets from a truck, but also advises a test fit. Beyond that piece of limited info, I'm clueless.
JamesC
Old Jul 5, 2009 | 01:27 PM
protek25's Avatar
Car: '84 Z28
Thanks, James. Sorry for the late reply, but I appreciate your answer. I checked out a lot of pictures, and realized that there are basically no problems with mixing and matching the brackets. The tpi versions of the serpentine system with the alternator on the drivers side all use the same bracket. And, since they all use the crank snout as their main pickup point for power, I fugure it must be the case that all of the various systems for the sbc must have pulleys that line up. The only problem might be the length of the belt. I think the truck belt will be right, and a junk yard will supply the "test" fit. The truck bracked without the smog pump is much more tidy looking, and leaves the fuel pump out in the open!
Thanks again for your responses. Mike H.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Genopsyde
Nov 11, 2015 10:46 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
