Fuel Lines
Old Jul 8, 2009 | 10:54 AM
jimcairns's Avatar
Fuel Lines
I have installed a Ram Jet 350 in my 1988 Camaro. Does anyone know where to find the fittings to attach to the factory hard lines to feed a -6 braideed steel line to the engine?
Old Jul 8, 2009 | 03:18 PM
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
Re: Fuel Lines
Here is a good link for part numbers. http://www.summitracing.com/search/?...0x%201.5&dds=1
What you need is a female 14mm x 1.5 and 16mm x1.5 for use with gm power steering and fuel lines. The male ends are for converting TPI fuel rails and TBI throttle bodies to 6AN. Make sure the fittings you get are compatible with the orings.
Hope this helps
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
