3.1 to carb 350, tv cable questions 700R4
Old Jul 20, 2009 | 02:05 PM
supersport92's Avatar
Car: 1992 RS camaro
Engine: chevy 350
Axle/Gears: 3.73 axle
i know alot of other people are running the setup as me, a 350 with a 700R4 tranny, my swap is done and i've gotta get this TV cable out of the way. i've done my homework and know i need something like these.
http://www.jegs.com/webapp/wcs/store...Term=holley+tv
but, is there any cheaper alternative, and i have an older holley i believe, or are all holley carbs compatible with the above parts.
Thank you for you consideration
Old Jul 20, 2009 | 02:37 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: 3.1 to carb 350, tv cable questions 700R4
I used this one from Summit. http://www.summitracing.com/parts/HLY-20-95/
Old Jul 20, 2009 | 08:40 PM
Car: 1992 RS camaro
Engine: chevy 350
thanks, and do you know if the throttle part is in the right spot for the cable, and i used the tv cable from the v6 tranny on my 700R4. that bracket should work for both cable from the v6 right? i really need to order my geometry corrector so i can be sure it will work.
Old Jul 21, 2009 | 07:10 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I used a tbi or v6 throttle cable. The motor wasnt in the car, but I had TPI and needed a shorter cable. You can try the v6 throttle cable, if it doesnt work, you can pick up a tbi version for cheap.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
