1986 camaro v6 to 350 carb swap. wiring help
Old Aug 2, 2009 | 07:36 AM
cutmesomeslack's Avatar
Car: 1984 GMC. soon to be 1986 camaro
Engine: Carb'd 350
Transmission: TH 350
Axle/Gears: Stock
Hi everyone this is my very first thread on here ive been doing a lot of reading on these forums and the have all been very useful. I just bought a 1986 Camaro Berlinetta v6 5 speed with no engine or trans for $400.00. The body is pretty much perfect. no dents at all and no rust at all all pans are good. there is a little rust under the trunk but its not bad. the interior with a good cleaning would be a 9/10 with the exception of the cracked dash. Ive pulled all of the ecm out and all the wires from the passenger side and i have removed the ac box because i want to put a delete box on for just heat. I have a roller 350 an a th350 transmission (long shaft) in a 1984 gmc that I want to put in. but I want to have my engine compartment completely perfect with anything that I dont need gone and every wire where it needs to be to hook right up. I have all the wires coming from the drivers side fire wall but i dont know where any of them go I have a pic here and I would like for someone to tell me which color wire goes where.
Attached Thumbnails 1986 camaro v6 to 350 carb swap. wiring help-camaro-025.jpg   1986 camaro v6 to 350 carb swap. wiring help-camaro-027.jpg   1986 camaro v6 to 350 carb swap. wiring help-camaro-028.jpg
Old Aug 2, 2009 | 07:41 AM
Engine: Carb'd 350
Axle/Gears: Stock
Re: 1986 camaro v6 to 350 carb swap. wiring help
more pictures of car. that is all the rust there is
Attached Thumbnails 1986 camaro v6 to 350 carb swap. wiring help-camaro-030.jpg   1986 camaro v6 to 350 carb swap. wiring help-camaro-050.jpg   1986 camaro v6 to 350 carb swap. wiring help-camaro-051.jpg
Old Aug 2, 2009 | 07:48 AM
Engine: Carb'd 350
Axle/Gears: Stock
here is some pics of the engine im putting in. will the hooker competition long tube headers fit? with a some work?
Attached Thumbnails 1986 camaro v6 to 350 carb swap. wiring help-camaro-041.jpg   1986 camaro v6 to 350 carb swap. wiring help-camaro-043.jpg   1986 camaro v6 to 350 carb swap. wiring help-camaro-044.jpg
Old Aug 2, 2009 | 07:52 AM
Engine: Carb'd 350
Axle/Gears: Stock
ok here is all the wires i need to know where they go
Attached Thumbnails 1986 camaro v6 to 350 carb swap. wiring help-camaro-035.jpg   1986 camaro v6 to 350 carb swap. wiring help-camaro-036.jpg   1986 camaro v6 to 350 carb swap. wiring help-camaro-037.jpg
Old Aug 2, 2009 | 07:56 AM
Engine: Carb'd 350
Axle/Gears: Stock
wires i unplugged from the ac box. which ones do i need just to run the blower motor for heat?
Attached Thumbnails 1986 camaro v6 to 350 carb swap. wiring help-camaro-038.jpg   1986 camaro v6 to 350 carb swap. wiring help-camaro-039.jpg
Old Aug 2, 2009 | 07:57 AM
Engine: Carb'd 350
Axle/Gears: Stock
also I have no clue how to open the hatch of the car
Old Aug 2, 2009 | 07:09 PM
Engine: Carb'd 350
Axle/Gears: Stock
can someone help?
meeklay812
Oct 1, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Gordonr1973
Sep 29, 2015 11:59 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
