wiring harness?? help!
Car: 91 Camaro RS
Engine: 305tbi out, 350tpi goin in
alright so i have a 91 camaro originally 305 tbi. ive taken all that out and im about to put a 350 tpi its a speed density setup. i have everything already for the swap except the harness. i found one here locally out of a 90 t/a. my question is whether the speed density harness out of a t/a is different or is it the same as a camaro's speed density harness? all the sensor connections look the same. will it just be a simple plug and play and im good?..and i guess what im really worried about is whether the bulkhead connectors to the firewall differ in any way between firebirds and camaros and between years 90-92? like i said my car is a 91 camaro and the harness is from a 90 t/a. will it work?(i havent bought it yet)please help the only threads i found were dealin with repinning stuff
and hopefully i dont have to do any of that.
and hopefully i dont have to do any of that. Joined: Oct 2007
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: wiring harness?? help!
If it's exact, which it could very well be, then you're good. If it's different on a few plugs, just add the right plugs where the wrong ones are. I'm pretty sure that from 85-92 or 87-92, the harnesses didn't change, or they changed very little. Here is a link where you can find plugs you may need, to build your harness, if they don't match up. http://tpiparts.net/82_92_camaro_wiring?start=0 There's 4 pages of plugs--you'll see if you scroll down a bit.
Car: 1986 camaro z28
Engine: vortec 5.7
in general, everything between firebird and camaro are the exact same, if there is a difference it would be a pin or two in the connector and would most likely be irrelevant to the motor. Supreme Member
Car: 1990
Axle/Gears: stock
i have a speed density from a ta 91 and it is for my 90 camaro. everything is the same - i will put in on in a few months but the wiring diagram is perfect.
and you need the computer too - so every wire before the firewall and after the firewall needs to be obtained.
i have to add - make it an original and not an aftermarked harness.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Transmission: T-5, TH350, T-5
The problem with the harness swap isn't at the firewall (c100 connection). Its at the connection from the computer to the harness under the dash (c207). TBI and port injection had two different speedometer setups among other things. I'm in the process of straightening out my car now. It would be a direct swap if it was a V6 car. This link has the diagrams. http://www.austinthirdgen.org/index.php?pid=19
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
i wanted to revive this and ask is there a difference between a harness from an auto and one from a manual car? no one has answered this yet from what ive searched
Transmission: 4L80E/4L80E
Yes, the auto harness will have the lock-up circuit and the manual will not.
