sbc 400 swap questions
Old Aug 5, 2009 | 09:23 PM
92FormulaBird's Avatar
ok so heres the deal i just found a prett good deal on a 400 sbc with heads pistons crank cams etc..almost everything i need but i was wondering what all would be necessary in order to swap from my 305 tbi to the carbd 400? any info would be helpful! thanks! =]
Old Aug 6, 2009 | 12:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There's a tech article linked from the thirdgen.org homepage that details the EFI to carb swap.
You'll either need to use the 400 starter (gets in the way of 3rd gen headers) of a 153-tooth, 2-piece rear main seal, externally balanced flexplate.
The dipstick will be on the drivers side. What are you planning for exhaust? Stock 305 exhaust manifolds will get in the way of the dipstick tube, and will choke a 400.
Stock 400 heads? If so, junk.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
camaro71633
Sep 1, 2015 10:24 AM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
