NEED Help with a 305, need to add more power!
Old Sep 9, 2009 | 12:37 PM
prodrigu2003's Avatar
Car: 91 Camaro RS
Engine: 305 TBI STOCK
Transmission: 5 Speed
Axle/Gears: 2:73
Now Everyone has told me to go with a 350, but I like My engine and dont want anything to drastic. Ive been told I could get some decent results from my engine with a set of vortec heads, cam, pistons, new fuel system and exhaust. Does anyone have specs or any advice? I have about 1500 to drop on parts.
Old Sep 9, 2009 | 12:42 PM
jm84z28's Avatar
Car: 1984 Z28 camaro
Engine: 388 ci stroker
Axle/Gears: 3:73
Re: NEED Help with a 305, need to add more power!
well if u dont want to 350 swap your car then could try bolt on's like long tubes, cat back, cold air intake,tune, gears, maybe a mild cam and roller rockers like 1.6 ratio
Old Sep 9, 2009 | 03:29 PM
sinkorskin's Avatar
Vortec heads will need to be milled or you will lose power from LOW compression. If you wana go cheap keep your short block stock, use a set of trick flow heads (summit sells them) with 56cc or 58cc chambers, crane cams emissions legal cam for 305/350, performer intake, turbo city ported throttle body 160' thermostat with fan switch controller and hypertech chip for these, upgrade your ignition with a box,coil,plugs and wires, headers ypipe and single exhaust (single makes more power than that shitty 80's series). This is a subject ive read a lot on. I have a 91 305 tbi. Check out http://www.goingfaster.com/spo/modthel03.html they have a lot of good ideas. Also www.hawksthirdgenparts.com amazing deals.
I have a coil plugs wires k/n 14"x3" with xtreme top plate. I am however switching to a 350 truck crate motor. But I am waiting on heads til i get the 350. all other components will switch. PS change your cat sensors and get a y pipe from hawks for throttle response will improve a lot.
Old Sep 9, 2009 | 09:50 PM
DJ_91RS's Avatar
Car: 91 RS, 89 IROC
Engine: 305 TBI, still deciding
Transmission: 700R-4, still deciding
Axle/Gears: stock, 3:73 IROC
If your motor is in ok condition I would look into a good exhaust and a set of gears for the rear end.
Dave
Old Sep 10, 2009 | 12:22 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
i did a 3.73 posi swap, shorty headers and a flowmaster catback with cat and smog delete and it ran a lot better
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
gta90
Sep 15, 2015 04:00 PM
sreZ28
Aug 14, 2015 07:48 PM
