Swapping 305 for 350, but mechanic said something about flywheel wtf
Old Oct 14, 2000 | 06:22 PM
mandob4c_1le's Avatar
Im getting complete 350 tpi into my 92b4c1le with 5 speed, but mechanic keeps giving me ru around now he says it needs a bigger flywheel because the one on there is too small. Ive never heard of this on any swap post. Please help any tips or advice would be appretiated. thanks
Old Oct 15, 2000 | 12:03 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
As far as I know and all the swappes I have been involved in you do not need a diffrent flywheel, unless one motor has a 2 pieace rear main seal( 85 and older)
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Oct 15, 2000 | 02:32 AM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
yeah, he's trying to mess with you... everything from a 350 will bolt up to a 305 and vice versa. Don't get screwed.
A 305 and a 350 are the same blocks!!
-=-Mike
Old Oct 15, 2000 | 03:10 AM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
Unless you have a truck crank in your motor i don't think you will have a problem.
If you get a different flywheel you might need to a different starter as well, or at least shim it.
Old Oct 15, 2000 | 02:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Does he mean flywheel or flexplate?
1984 Silver Z28, 383 cid 4 bolt, ARP Fasteners, 2 1/2" Cowl Induction Hood, 600 cfm Performer Carburetor, Torker II Intake, Performer RPM Heads, XE268H Cam, Magnum Roller Tip Rockers, MSD6AL Ignition, Blaster2 Coil, Recurved HEI Distributor, 700R4, TransGo SK, 2.73:1 Limited Slip Dana 44, Terminator Headers, Custom 3" TIG Welded Stainless Exhaust, Flowmaster Muffler, 4 Wheel Disc Brakes, Oil Cooler
Old Oct 15, 2000 | 04:00 PM
Thanks for the replies, but he said flywheel, but maybe he ment flexplate. Does it have to do with the swap as far as it beign to small? The engine is from a 92z28. Ill have to make sure what he means tomorrow.
Old Oct 17, 2000 | 02:32 PM
84FBODY's Avatar
I know after I swapped a 1979 350 into my '84 camaro and then toasted the FLEXPLATE I went and got a flexplate for a 1979 350 engine. That Flexplate was too big because of the cutout in the bellhousing. It wouldn't fit on and still allo wmys tarted to mount where it normally should mount so I had to take it back and waste an extra 15 bucks to get the smller flexplate for a 305. Don't worry though. It's plenty strong enough. Mine broke because I don't think I had the tranny bolted tightly against the engine. So now I'm out a tranny. Ahh such is life! Everyone else is right though. DONT GET SCREWED. 350's and 305's are same block as long as it's same year or newer. Like that one person said 85 or older is 2 piece rear main so be careful. just use 305 flywheel on 350 and you'll be fine. By the by. FLEXPLATE is auto Flywheel is Manual. Same thing different name.
John Chamberlain
1984 Sport Coupe Camaro, 1979 350. Dynomax 2 3/4" cat back single in dual out muffler. Saving for Headers, Heads, And new Intake. Then.... PAINT
The Allmighty Warrior Court Jester of The Not-So-Famous Cascade Crew
[This message has been edited by 84FBODY (edited October 17, 2000).]
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
st.evel07
Aug 13, 2015 06:15 PM
