Vortec heads/Qjet carb
Old Oct 21, 2000 | 12:35 AM
amagin86's Avatar
I'm planning on a 350 for my '83 Z28 Five speed car. I've been looking at PAW's block kits. My question is, if i get a short block and vortec heads, is anyone making a manifolt yet to use a spreadbore carb. I see an edelbrock part number 3706 but i think maybe this is just for use with the '87 and up heads. Am i right in thinking that the vortec heads are different still than these.
Hopefully someone's done this and can tell me if there's a manifold or not. If there is then i'll start thinking about carb tuning and computer stuff.
i am planning on keeping the computer, and hopefully all the emmisions stuff.
thanks
alex m
columbia mo
Old Oct 21, 2000 | 03:41 AM
Wolfcoast's Avatar
The vortec heads have to have a vortec-specific manifold due to the different bolt pattern. Edelbrock makes one and I believe it will accept spread or squarebore.
Randy
84 Trans AM LG4, 700R4 T-tops
1984 Z28 L69, 5 Spd, T-tops
"Don't sweat the petty things...Just pet the sweaty things"
Old Oct 22, 2000 | 12:09 AM
NO RICE's Avatar
Unless Edelbrock changed it's design.. The intake only takes Holle flange... I have one.... Just get an adapter.. $13
Old Oct 22, 2000 | 11:54 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
the performer intake (edl 2116) accepts QJ I believe, however, the performer RPM does not
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
Old Oct 22, 2000 | 12:08 PM
Wolfcoast's Avatar
vortecfcar is correct...
The edelbrock Performer Vortec Manifold ($2116) will accept square or spreadbore.
The Performer RPM (#7101) will only accept squarebore
At least that's what my 2000 Edelbrock Catalog says hehehe
Randy
Randy
Old Oct 22, 2000 | 11:16 PM
amagin86's Avatar
thanks so much for all the info folks. i'm glad to here i won't be having to use a spacer. i'm a trans am series race mechanic and i'd get harrassed for such butchery, not to mention it might cause hood clearance problems on my '83 Z28.
anyone have good/bad experience with the vortec heads. the magazines won't shut up about them and they sound like a good deal for around $400.
thanks again
alex m
columbia mo
Old Oct 23, 2000 | 12:29 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
I think you'll be pleased. Use the right intake gasket and torque to 11FT lbs! I believe. This intake bolt arrangement is something hey should have used years ago! I love the heads.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
69GTOby
Apr 18, 2016 02:34 PM
BLK87Z
Sep 18, 2015 11:29 PM
sandman92084
Sep 12, 2015 10:27 PM
