94 LT1 into 90 forula 350
Old Oct 13, 2000 | 05:08 PM
90Formual350's Avatar
i got a 90 formula 350 and i have come across a 94 camaro Z28 w/the lt1 motor.could i take the topend of this motor and put it on mine w/no trouble.my motor is all sock right now.expect exhaust.if i can do this would it be a good hp gain?????
Old Oct 13, 2000 | 11:02 PM
Get Blown ?'s Avatar
NO, the LT1 isn't like your average small block. Coolant flows the opposite way. So this changes the whole way the engine is internally. If you want a LT1 like intake for your L98 get a Miniram.
1989 Camaro RS LO3 WCT5 "The Hose Queen" 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
ICQ: 61342629 AOL IM: BlackSunshineZ28
Old Oct 17, 2000 | 02:18 PM
Greg90iroc's Avatar
ok why would you want an lt1 in your car? first they lack the low end grunt the l98 has second after you get a good exhaust and a fuel regulator on the car they lack the upper rpm power that my l98 has. it is a lose lose proposition. i don't think that the lt1 was all it is cracked up to be.
90 iroc l98
last season best corected 13.62 @102
mods
full exhaust, AFPR, pulley, jet stage 1 chip, billet servo, 52mm throttle body and a few other little things.
Old Oct 18, 2000 | 12:15 AM
Brett's Avatar
What if you put a full exhaust and AFPR on an LT1? Then it would be just as nasty as any L98 with similar mods. Both engines are *relatively* equal. The L98 makes a little more grunt down low and the LT1 walks them on the top end because it can SPIN up in the rpms. I've had both and modified both. On a pure ease of swap level, the L98 would be easier since a 90 Iroc should already have been TPI.
I think of it this way - if I'm going to gear the hell out of my car then I want an engine that will make power at high rpms.
If I were to pick between those two engines for a swap as an internally stock engine for street use and an occasional dusting I would pick the L98 since it's the easier swap and because it makes that little extra ooomph off the line.
If I were planning any level of mods like cam/head work I'd go for the LT1. It has high compression, high rpm, and if you change the pistons it loves nitrous.
Old Oct 25, 2000 | 03:24 AM
LT1Powered85Z's Avatar
Car: '85 Z28
Engine: 396ci LT1
Axle/Gears: 4th Gen rear with 4.10s/Eaton posi
LT1 all the way, unless you're worried about the difficulty of the swap.
How many stock L98s are there out there that'll hang with or beat a stock LT1? I haven't seen it happen yet. There's a difference between 245hp and 285hp. The torque figures are closer than the HP, but on the top end the HP helps win the battle.
I'd much rather have my LT1 than an L98. I had an LB9, which produced its fair share of torque, and I actually still own one...but the LT1 is much more fun, overall.
Eric
Red '85 Z-28 w/'94 Vette LT1 w/'93 Z ECM
Red '85 Z-28 w/LB9
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
New2Chevy
Sep 28, 2015 12:35 AM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
