700r4
Car: 91 RS
Engine: 350 Carb
Transmission: TH-350
Axle/Gears: Stock 3.23
700r4
I know you cant use a 3.1 liter 700r4 with a v8 swap. My question is. Is the proper 700r4 the same dimensions as the v6 version. I know the bell housing is smaller but will the two mount in the same location without modifications.
Transmission: 4L80E/4L80E
Other than the bellhousing pattern, all other external dimensions are the same.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
