502 ram jet, everything about fuel...
Old Sep 12, 2009 | 06:34 PM
engongam's Avatar
Car: 1991 Trans Am GTA
Engine: 502 Ram Jet
Transmission: TKO600-racing gears
Axle/Gears: 12 Bolt Moser-33"axles-3.91 ratio
Hello,
I will buy a new fuel pump and fuel regulator, I have a 91 Trans Am GTA and I did my swap successfully (enough) I need to regulate my fuel pressure to 47-55psi (with the vacuum hose disconnected) My question to you is that are these products fine to my engine and car...
regulator:
http://www.summitracing.com/parts/MA...M/?image=large
pump:
http://www.summitracing.com/parts/BBK-1630/
(I know that 100psi is not necessary but I am planning to do a NOS upgrade so I might need it)
gauge:
http://www.summitracing.com/parts/ATM-2663/
The price high, I wonder why, Is it because of the sending unit? There are 45 $ gauges with no sender units...
Thank you
ps: you can have a look at the project from this link: https://www.thirdgen.org/forums/engi...305-502-a.html
and watch the video: https://www.thirdgen.org/forums/memb...deo-502-a.html
Old Sep 15, 2009 | 01:06 AM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
Re: 502 ram jet, everything about fuel...
i replyed to your other thread before seeing this one, but those parts should work fine,
Edit: the regulator is fine.
another fuel pump to look at is the walbro 255 units. very good pumps as well, and are used by alot of people on here and across the world. good stuff!
im not sure on the bbk unit, i havent heard anything bad or good for that matter.
auto meter is practically the industry standard in gauges. its price is because its electric, normally means more $$. the cheaper ones arent ment to be mounted inside for safety reasons.
they make in car fuel pressure gauges that are not electric as well, they use a diaphram that actuates a neutral fluid to feed the gauge.
Old Sep 15, 2009 | 05:34 AM
engongam's Avatar
Engine: 502 Ram Jet
Ok than, I found the pump you said, It is better to buy the pump that has already been tried....
http://www.summitracing.com/parts/VP...2/?image=large
Is this the one?
255 psi is too much, I need to use a regulator but the regulator that I only found supports max 100psi, Does it mean that It can only reduce to 100psi? or It works with max 100psi inlet pressure?
Can you suggest one as well if the one that I showed is not ok or If there is a better one...
Thanks for the reply...
Old Sep 15, 2009 | 05:40 AM
engongam's Avatar
Engine: 502 Ram Jet
Upsss it was not 255 psi (phhyy what was I talking about), It was 255lph so I guess it is around 51-54 psi right?
My question about picking the right regulator still valid.
Old Sep 15, 2009 | 09:05 AM
that regulator will work, i forgot that fi uses the vacum nipple, my bad. i run a carbed setup.
Old Sep 15, 2009 | 03:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Either the Walbro or BBK pump would be fine. They are rated free flow, not pressurized flow. But, either will support the 502 just fine.
The regulator has the vacuum fitting, which lowers pressure at idle and cruise. I don't know what GM says the 502 pressure requirements are. The instructions that came with the engine should tell you were to set it and whether to use the vacuum port on the regulator.
Old Sep 15, 2009 | 03:39 PM
engongam's Avatar
Engine: 502 Ram Jet
"The 48-55psi figure is with the fuel pressure regulator vacuum line disconnected" the manual says... and more 37psi (I guess) is the vacuum hose connected... Am I right?
Old Sep 15, 2009 | 04:02 PM
five7kid's Avatar
Sounds right.
Old Sep 15, 2009 | 04:04 PM
engongam's Avatar
Engine: 502 Ram Jet
Ok, thanks for the reply...
Linson
Oct 24, 2025 02:00 PM
cowansauto
Apr 3, 2025 12:51 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
mfp189
Sep 27, 2015 09:25 AM
