What do you look for when buying a chevy 350 to rebuild
Old Sep 14, 2009 | 03:14 PM
jwdrouyor's Avatar
Car: 1985 Chevrolet Camaro Z28
Engine: 8 Cylinders 5.0L FI
Transmission: Automatic
1985 chevrolet
Hello im in need of a new engine and i will be swaping my 305 for a 350
now im looking into buying a 350 and rebuilding it then just swap it out.
now my funds are tight
how much would a 350 block in need of a rebuild cost?
And then what should i look for?
i heard not all blocks can be brought back to life is that true?
Old Sep 14, 2009 | 03:58 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: What do you look for when buying a chevy 350 to rebuild
1 - Anywhere from free on up. At least that's what you can get them for in PA. Personally, I wouldn't pay more than $250 for a good rebuildable block.
2 - That all depends on what you want to do with it and how much money you have to put into it. If its not cracked it can usually be rebuilt. The only thing that will really determine if the block can be rebuilt is the block. Heads/crank/pistons/cam/bearings/etc, everthing else can be replaced. In some cases, like bearings, they MUST be replaced. Pull the heads and check the cylinder walls. You won't be able to see the entire bore on every cylinder because of the pistons, but look at what you can. Check for scratches/deep grooves and cracks. Turn it over and pull the pan. Check around the main caps and their supports for cracks and chips. Take a caliper to measure the cylinder bores to make sure they are not at their limit. Ideally they should be right at 4.000" and not more than 4.030" so you can have them bored if necessary.
If you want to do this as cheaply as possible, check the crank journals for scratches/scoring/pits and the pistons for the same. Check the heads for cracks/bent valves/broken springs. Check the cam & other bearings for wear. Normal wear/small scratches are fine but if they are real bad it can be a sign the engine was starved for oil(like in my truck).
3 - Yes, its true. Although the vast majority are good for rebuilding, some take more time & $$ to bring back to life than others do. As long as the block is not cracked and the cylinders are at their size limit(usually .060" oversize) then you should be able to rebuild it.
Old Sep 14, 2009 | 04:18 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
For the '87-up blocks, which are the best choice because of the roller lifters and the 1-piece rear main seal, beware of cracks in the lifter valley. These blocks can be had for $100 around here.
Old Sep 15, 2009 | 03:20 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
The 1-piece rear main was on all of the 87+ blocks, but some trucks were a bit late to the party when it came to hydraulic roller. something to be on the lookout for.
best cheap stock-ish setup I can think of -
1pc rear main
4bolt
vortec heads
Old Sep 15, 2009 | 03:54 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
1pc rear main
4bolt
vortec heads
Good point about the truck engines. However, since the OP is in CA I'm pretty sure he has to stick with a car engine anyhow to pass smog.
Also, to get 400HP a 2 bolt should be just fine.
Old Sep 16, 2009 | 07:08 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Oops, missed the CA part. That definitely makes things more difficult.
Jake_92RS
Jan 28, 2020 10:37 PM
BADNBLK
Nov 16, 2016 09:12 AM
Reborn756
Sep 4, 2015 03:42 AM
NinjaNife
Aug 23, 2015 11:49 AM
86White_T/A305
Aug 17, 2015 12:16 AM
