400 sbc power question
Old Nov 5, 2000 | 08:51 PM
Chris305TBI's Avatar
I'm about to start building a 400 sb, and was wondering what eveyone thought about this setup and how much power it would make:
406 w/ forged pistons
Brodix Aluminum heads: 69 cc chambers 170int.
244int 254ex @50 cam with 510 533 lift
Victor Jr intake
Hooker Super Comp Headers w/ full exhaust
@250 shot of NOS with complete fuel system
I dont' know which carb to go with but you get the point. Do you think this is a good setup? Also if anyone knows where i can find a block for cheap, please let me know.
Old Nov 5, 2000 | 10:00 PM
89ProchargedROC's Avatar
Very nice combo, but with that cam you need some good gearing, i would say at least 3.73 and a good stall. i would go with 3200-3500 at least. Also, brodix makes nice heads, but those are too small. 400's need to breathe and 170cc intake isn't even big enough for a built 350. I would go with something around 200cc or 215cc since you have a high reving cam and a victor jr.
Old Nov 5, 2000 | 10:29 PM
Do you think the Trick Flow 23 degree heads would be better with this setup: 195cc intake runners 64 72cc chambers( I could still port and polish these up pretty good since they are cheaper than the Brodix's)
I want a lower compression motor that handle a lot of spray, but still tear *** without it.
A six speed out of a camaro will be behind this motor with 4:10's.
What would be a good carb to go with?
thanks
chris
Old Nov 5, 2000 | 10:33 PM
Novaguy76's Avatar
This is true.. you will need better heads than that... You might want to save yourself about $300 and go with the Pro Action Iron Lighting heads. They have 210cc and flow 271 @ 600 lift out of the box. For around $800 you can not beat them.
Old Nov 5, 2000 | 10:45 PM
Novaguy76's Avatar
Here are the flow numbers for the Iropn lightining heads and the websight to check them out http://www.procylinderheads.com/
Intake Valve Test Data @28" of water
.100 .200 .300 .400 .500 .600
70.74 146.41 204.62 249.84 264.62 272.23
.700 282.08
Exhaust Valve Test Data @28" of water
60.22 114.27 151.72 177.8 183.0 190.71 .700
195.24
Old Nov 6, 2000 | 02:40 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
with that setup i wouldnt settle for less than 850cfm. btw...what is the best flowing intake edelbrock makes?? victor jr? performer rpm? thanks.
Rick
90 Camaro RS 305 TBI
400 on the way!!
Old Nov 6, 2000 | 04:36 AM
Novaguy76's Avatar
The best flowing Edelbrock intake is a Super Victor. To tell you the truth I would go with a Holley 750 with this set up. You can do alot more than you think with a 750. You wouldn't need an 850 till you got a 12.1 406 with at least a 260 @.050 solid roller cam. Before you choose a carb though you need to think about tuneablity. A vacuum secondary carb you can tun the secondaries to open slower or faster but with a double pumper it is easier to change the jetting in the rear because it uses jets instead of a meatering plate so you have more control over your set up. If you don't want to be messing with the carb all the time then go with a vacuum secondary if you like to tinker with your tune up then go with the more adjustable bouble pumper.
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
camaro71633
Sep 1, 2015 10:24 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
