327 Vortec (LM7) into 92 f-body
Old Nov 7, 2000 | 02:52 PM
UnderDogRS's Avatar
what would be needed to put a 327 vortec(LM7 is related to LS1) into a 92 f-body that came w 305 auto tbi 2.72 in the rear. that 327 has almost all part and computer.
tia,
RS
(A.K.A FireBird88)
AOL SN: Zander0710
1992 Camaro RS 25th anniversary edition Adopted Feb,14 2000
Mods:
14x3 Open element w/ K&N filter, MSD GM blaster Coil and 8.5 SC wires, AFPR, 60psi. Fuel Pressure gauge, 3-Row Al rad. , 180* t-stat, Hooker 1 5/8 headers, 3" Catco cat, 3" Hooker Aero Chamber cat-back, "Ultimate TBI" mods
Old Nov 7, 2000 | 04:03 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
Ive never heard of this engine before, I thought the 327s died in '68. Or are you refering to the new 5.3Litres in the trucks?
Old Nov 7, 2000 | 07:00 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Seasoning actually has a specific meaning (or use to)...it means the block is stress-reliefed.
Old Nov 7, 2000 | 07:03 PM
Car: Death Mobile
Engine: 666 c.i.
Sorry.. this is cross-posted from another thread...I haven't seen this problem at www.thirdgen.org in quite awhile.
Yes, their is a NEW 327 based on the LS-2 (6.0L iron version of the LS-1). They are found in the new trucks.
Regarding the swap.. it would involve the same things as if you were to swap an LS-1 or LS-2.
Old Nov 8, 2000 | 04:23 AM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
why not just go with a standard 350 with Vortec heads? it would probably be a lot easier of a swap, was for me. i simply swapped topend with the dif block. plus im pretty sure can coax more power out of the 350 version,
(350-400hp)
unless you wanna try something different?
thats a cool idea if thats the case.
good luck,
Jeremy
1982 Camaro Z28...$1000
Vortec 350 block rebuilt 20 over.. $900
L31 Vortec heads...$0 xtreme energy comp cam... $200
Edelbrock carb/intake...$500
home made cold air/ram air induction...$0
dynomax headers...$150
flowmaster 3chamber...$250
rebuild diff, 3.73 richmond swap... $900 built 7004r w/ stock converter... $200
Dusting a 2000 GT with my "truck motor"...
PRICELESS
Old Nov 8, 2000 | 05:16 AM
Novaguy76's Avatar
Yes I think he is talking about the 5.3 liter in the new trucks. That would not be a bad motor to put into your F-body considering they put out 285hp. I don't think it would be any different than swapping in an LS1. Not that I have done that swap or know anyone that has but I am sure someone on here has seen it done.
69GTOby
Apr 18, 2016 02:34 PM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Nervous2
Oct 8, 2015 10:53 PM
monte87cortez
Sep 26, 2015 08:10 PM
